Configuring DIO lines at runtime
Jon Sweeney
Does anyone have a DAQmx example or description for setting DIO lines (eg, NI6225M) at runtime - some lines to outputs and some to inputs.
I have done this with the old Daq "Port Configure" vi but am having trouble determining how to do it with DAQmx.
Thank you.
Jon
QUOTE(ned @ Oct 3 2007, 07:47 AM)
  Quote
Here's one way to do it. If you need to change the direction of lines as your code is running, you can clear the existing tasks and create new ones with the lines set as necessary. The VI on the left is "DAQmx Flatten Channel String" from DAQmx - Data Acquisition -> DAQmx Advanced -> DAQmx Utilities; the one on the right is "DAQmx Create Virtual Channel".
Thanks. I'll give that a try.
Jon
