Vadim Posted October 3, 2007 Report Share Posted October 3, 2007 Hi everyone who reads this!!! I have an issue with Chart which represents data versus current TIME. We are limited to TIME format which is HH:MM (no seconds, no date whatsoever) When LV program starts executing the first data points displayed at the Chart vs TIME. GOAL: NOT ALLOW TIME AXIS TO DISPLAY THE SAME TIME VALUES AT X-axis. For example: CHART displays 14:00 as start point and also displays 14:00 as the end point, we can't allow those time values to be the same. They have to be significant by at least 1 min. If someone has any idea how to solve this issue please let me know. Regars, VK Some of my ideas: I can set up "CHART HISTORY LENGTH" to be > 60, and have only 2 values displayed representing TIME (located at the most bottom left and the most b. right corners), so afer maximum of 1 minute CHART TIME values are always significant, but how to set/make them significant at the beginning? Let's say: 0 time point is current time - 1 min.(T0=14:00 - 01:00, TF=14:00)? Quote Link to comment
Ton Plomp Posted October 4, 2007 Report Share Posted October 4, 2007 Too bad you didn't post some code you allready tried, now we have to guess. I would try this: Ton Quote Link to comment
