Members can change display name once this weekend
Just want to let you know that as a courtesy to normal members. I am allowing you to change your display name once. The opportunity do do this expires on Sunday night. Some display names are ugly because of a previous login limitation prohibiting spaces or underscores. I have lifted this limitation so now you can beautify your display name and use spaces or underscores or whatever.
Note: this is a one-time deal. Make sure you are sure of the new name because you won't be able to change it starting Monday.
You can change your name in your control panel. on the left side select Change Display name.
