ERROR - 200279
sahara agrasen
hi,
i m getting the error in my data acquisition system...the error indicated the memory is full..i mean to say the excel sheet becomes full in the first execution..
i dont know what happening....here i m attaching the real error msg what i m getting is .....
Possible reason(s):
Attempted to read samples that are no longer available. The requested sample was previously available, but has since been overwritten.
Increasing the buffer size, reading the data more frequently, or specifying a fixed number of samples to read instead of reading all available samples might correct the problem.
Property: RelativeTo
Corresponding Value: Current Read Position
Property: Offset
Task Name: _unnamedTask<4E>
can anybody helps me in this regards....
Sahara
QUOTE(sahara agrasen @ Oct 27 2007, 08:35 PM)
hi,
Sahara
Sahara,
could you add your code?
Ton (I could make up 0x20 ways to get this error)
