DaveKielpinski Posted November 6, 2007 Report Share Posted November 6, 2007 Dear all, I'm trying to create a UI consisting of a graph and an overlaid picture with various decorations. However, I need an event to fire when I double-click on the graph in order to get the graph coordinates for the event. I can't seem to accomplish this when the overlay covers the plot area - then the "mouse down" event can never be associated with the graph, only with the overlay. Solutions I have tried: 1) Change the order of the controls programmatically - the cleanest solution. You can do this in edit mode with the Align/Distribute/Reorder toolbar, but there doesn't seem to be a corresponding property for doing it at runtime. Am I missing something? If not, I think this is a significant flaw in Labview. 2) Move the overlay far outside the front panel window on the first mouse click, then bring it back after the second. This kind of works, but makes for an unsatisfying UI. 3) Use dynamic event registration to disable the "mouse down" event for the overlay on the first mouse click, so that the second click can be associated with a "mouse down" event on the graph. This would only work if disabling an event on a control allowed that kind of event to "pass through" to the next control in line. Unfortunately Labview isn't set up like that, so it also doesn't work. All this is a nice learning experience, but I would rather have a working piece of code right now. Could someone give me a hint? Thanks, Dave Quote Link to comment
Ton Plomp Posted November 6, 2007 Report Share Posted November 6, 2007 QUOTE(DaveKielpinski @ Nov 5 2007, 10:45 AM) Dear all,I'm trying to create a UI consisting of a graph and an overlaid picture with various decorations. However, I need an event to fire when I double-click on the graph in order to get the graph coordinates for the event. I can't seem to accomplish this when the overlay covers the plot area - then the "mouse down" event can never be associated with the graph, only with the overlay. Solutions I have tried: 1) Change the order of the controls programmatically - the cleanest solution. You can do this in edit mode with the Align/Distribute/Reorder toolbar, but there doesn't seem to be a corresponding property for doing it at runtime. Am I missing something? If not, I think this is a significant flaw in Labview. 2) Move the overlay far outside the front panel window on the first mouse click, then bring it back after the second. This kind of works, but makes for an unsatisfying UI. 3) Use dynamic event registration to disable the "mouse down" event for the overlay on the first mouse click, so that the second click can be associated with a "mouse down" event on the graph. This would only work if disabling an event on a control allowed that kind of event to "pass through" to the next control in line. Unfortunately Labview isn't set up like that, so it also doesn't work. All this is a nice learning experience, but I would rather have a working piece of code right now. Could someone give me a hint? Thanks, Dave You can add an image to an 8.5 graph as an overlay, underlay. In that case you won't have issues. Could you show the code + an image of the wanted layout? Ton Quote Link to comment
DaveKielpinski Posted November 6, 2007 Author Report Share Posted November 6, 2007 QUOTE(tcplomp @ Nov 5 2007, 08:40 PM) You can add an image to an 8.5 graph as an overlay, underlay. In that case you won't have issues.Could you show the code + an image of the wanted layout? Ton hmm... I'm only running 8.2.1 for the moment. I didn't find any overlay/underlay features for graphs in my version, and I couldn't find any documentation of such a feature on the NI site. As for code, I can show you lots of it, according to the things I previously tried (listed in my post). But it would probably be too tedious for you. The main problem is not actually overlaying the picture on the graph - I've got that worked out. The problem is that once I overlay the picture on the graph, I can no longer get events associated with the graph. Thanks, Dave Quote Link to comment
Ton Plomp Posted November 6, 2007 Report Share Posted November 6, 2007 QUOTE(DaveKielpinski @ Nov 5 2007, 12:01 PM) As for code, I can show you lots of it, according to the things I previously tried (listed in my post). But it would probably be too tedious for you. Try me Have a look at the following properties: PlotImages.Back (behind the curves and raster) PlotImages.Front (for curves and raster) PlotImages.Middle (in between curves and raster) These are only present for graphs and available in LabVIEW 8.2 as well To calculate from pane/panel coordinates to graph coordinates the PlotBounds property might be usefull. A better way is the 'Map Coords to XY' method wich converts pane coordinates (returned by a mouse down event on a decoration) to X and Y coordinates of a graph. Ton Quote Link to comment
DaveKielpinski Posted November 8, 2007 Author Report Share Posted November 8, 2007 Thanks Ton! It is good to know about those "Plot Image" properties. Unfortunately the XControl I was envisioning will not work for other reasons. For instance, I wanted to have a graph X-axis with different scaling at different parts of the graph. This seems flatly impossible. I wonder if I am discovering the limitations of Labview. It seems like NI's philosophy is to make Labview the most general WYSIWYG programming interface possible. However, the permutations that fools like me can come up with will just exceed anyone's imagination. Of course it is possible to program in Labview in a way that goes against NI's philosophy, but if you take it to an extreme, you just end up programming in a graphical version of C without all the open-source user libraries. /rant Quote Link to comment
tnt Posted November 8, 2007 Report Share Posted November 8, 2007 QUOTE(DaveKielpinski @ Nov 7 2007, 01:33 PM) For instance, I wanted to have a graph X-axis with different scaling at different parts of the graph. This seems flatly impossible.Hi,did you take a look at the picture plot (see LV examples)? The graph is plotted completely into a picture control so virtualy everything becomes possible... TNT Quote Link to comment
Ton Plomp Posted November 8, 2007 Report Share Posted November 8, 2007 QUOTE(DaveKielpinski @ Nov 7 2007, 12:33 PM) I wonder if I am discovering the limitations of Labview. It seems like NI's philosophy is to make Labview the most general WYSIWYG programming interface possible. However, the permutations that fools like me can come up with will just exceed anyone's imagination. Of course it is possible to program in Labview in a way that goes against NI's philosophy, but if you take it to an extreme, you just end up programming in a graphical version of C without all the open-source user libraries. Labwindows? The power of LabVIEW is the block diagram (IMHO) and not the UI. Dataflow is something I . If you want to have a mixed axis the picture is control is the tool for you. NI has provided a lot of 'open source user libraries' to build axis and make your own graphs. Ton Quote Link to comment
