Palette Icon for an XNode
Tomi Maila
I've developed some XNodes that I now want to add to functions palette. The problem is that I don't know how to define the palette icon for an XNode. If I add MyXNode.xnode to functions palette, then for some reason LabVIEW shows the icon of MyXNode.xnode:Help.vi and not the library icon. Has anybody succesfully defined the palette icon of the XNode?
Tomi
I had the same problem.
By error and trial I figure out that you have to change the icon of the help ability and the palette will display it. Just to be safe I typically put the icon I want in both the XNode and in the Help ability. If you don't have a help ability I think you can use the initialize ability icon.
PJM
QUOTE(PJM_labview @ Nov 7 2007, 07:20 PM)
Thanks :) I'll use the Help ability then to specify the palette icon. I just got ready my first actually useful set of XNodes that are not only playing around but actually meant for powerful programming tools :)
Tomi
QUOTE(Tomi Maila @ Nov 7 2007, 05:47 PM)
Yes, it's easy. Things go more or less like this:
  1. If your XNode has a description, the palette will show the XNode library icon.
  2. If the XNode doesn't have a description, then the palette will show the Help VI icon.
  3. If the XNode doesn't have a description nor the Help Ability, then the palette will show the Initialize VI icon.
  4. If the XNode has no description, no Help and no Initialize, the palette won't accept it.
So, use a description :yes:
Saludos,
Aitor
