M.M.K
QUOTE(M.M.K @ Nov 18 2007, 10:47 AM)
The output dose not reaches the Max. value
Because i goes from 0 to N-1, so your last iteration output is MAX - INC. Add a +1 to the N or to the i. Keep also in mind that you are casting a double to an int when you set the N value; you have no guarantee the selected increment can reach the max value (for example, if MIN=0, MAX=1 and Increment=0.3, you won't reach 1 but 0.9 or 1.2, depending on the N value).
Saludos,
Aitor
I agree with Aitor.
And you must connect to N of For Loop only an Integer. For exmple if you connect the value 3.4 the For Loop will interact 3 times and the value of i will be 2
