Closing Array of References
I saw something interesting at the bottom of a LAVA WIKI page. Apparently you can close an array of references in one shot by passing the array (of references) directly to the Close Reference vi.
I tried it... but got a conflicting class error. Can anyone shed a bit of light on this?
Thanks!
RayR
Works at least in LabVIEW 8.5 with the limitation that the references need to be of same class hierarchy. One cannot close a VI ref and and a control ref together but array of front panel objects can be closed at one go.
QUOTE(JoeLabview @ Nov 29 2007, 11:52 AM)
Thanks!
RayR
RayR,
The ability to close an array of references was introduced in LabVIEW 8.5. To do this in earlier versions, you will need to use a For loop.
Chris M
