Venke Posted December 7, 2007 Report Posted December 7, 2007 Using the VI I have constructed I am able to talk via the regular COM port to another PC but when I try communicating via the Virtual COM port I uable to do so. The driver for the virtual COM port is correctly installed and that is why I am even able to select the port. But when I run the code it executes without error but there is no output on the other side. Any clue???!!! Quote
TobyD Posted December 7, 2007 Report Posted December 7, 2007 QUOTE(Venke @ Dec 6 2007, 06:49 AM) Quote Using the VI I have constructed I am able to talk via the regular COM port to another PC but when I try communicating via the Virtual COM port I uable to do so.The driver for the virtual COM port is correctly installed and that is why I am even able to select the port. But when I run the code it executes without error but there is no output on the other side. Any clue???!!! Can you post your code and tell us what software you are running to create the virtual com port (and on what operating system)? Quote
