Library and Class Icons cannot be applied
If I read the help correctly every time you change the icon for a LVOOP class (.lvclass) or a library (.lvlib) you should be prompted whether you want to apply the changes to all icons in the class/library. That does not happen in LV 8.5. I am pretty sure it worked in 8.2.
However, if I open a reference to a library I can use an invoke node to call 'ApplyIconToVIs', which works fine.
QUOTE(hfettig @ Dec 11 2007, 10:39 AM)
Um... backwards. The dialog to ask "do you want to apply lib icon to members" was new in 8.5. It wasn't there in 8.2.
