RovingCalypso Posted December 19, 2007 Report Share Posted December 19, 2007 I need to draw a circle over a polar plot in labview 7.1. How do I do that? (A step by step guide will be appreciated) I've found the circle drawing function, but am having problems with its input, especially that pixel centre one. Thanks Quote Link to comment
Ton Plomp Posted December 19, 2007 Report Share Posted December 19, 2007 QUOTE(RovingCalypso @ Dec 18 2007, 10:06 AM) I need to draw a circle over a polar plot in labview 7.1. How do I do that? (A step by step guide will be appreciated)I've found the circle drawing function, but am having problems with its input, especially that pixel centre one. Thanks Well, with this post you most unlikely get a good answer. Could you attach your code and describe what you have tried? If you open up the 'Draw Polar Grids.vi' (this will be in your 'Unopened VIs' list, you will see how the current grid is drawn. Use this for your needs! Ton Quote Link to comment
