Can't get the graphs moving.
xbt87
i have made a temperature sensor circuit and i wish to display the output to the labview prog.
using microchip's 44pin demo board and data are transmitted wirelessly.
there are some input on the labview , however nothing is shown on the graph...
using version 8.20 student edition.
please advice thanks.
image url : http://img530.imageshack.us/img530/1506/sensorlabvtq1.jpg
http://img257.imageshack.us/img257/2121/blkdsy0.jpg
QUOTE(xbt87 @ Dec 21 2007, 06:51 AM)
[tip]Please use LAVA stored images, http://forums.lavag.org/FixedBoard-width-New-lay-out-is-very-wide-t4769.html#' target="_blank">see here why[/tip]
One thing, a graph will never store previous runs.
But it looks like you used a chart, so that shouldn't give a problem.
Are you sure your values are in the range of the plot? Try putting on 'Autosclae' for X and Y scale.
Another issue, your current 'String' doens't show the type-specifiers 'voltage' or 'tempdeg' so the scanning won't find anything usefull.
You need a more sophisticated routine to do the string parsing.
Ton
