encoding wav files into mp3
Hi all,
I am building an application that accumulates lots of data. There are also some microphones involved to add some context to the measurement while postprocessing. The measurement will run autonomously and therefore I need to save disk space where ever I can.
I am saving the sound information as WAV files, and I would like to compress them as much as I can. I will use a frugal format of 11025 kHz single channel 16 bit data.
I experimented a bit with compressing to zip, rar, OGG and MP3. A file size of 948 KB compressed as to the following sizes:
original 948 KB
zip 719 KB :thumbdown:
rar 577 KB
OGG 178 KB
mp3PRO 133 KB (86% compression!) :thumbup:
The difference between OGG and mp3PRO is circumstantial, since I tried hard to optimize the settings of the mp3 codec. The sound quality is not an issue and I really couldn't even hear the difference anyway.
Obviously I would like to encode the data to mp3, and there lies my challange: what utility to use to programmatically encode data to mp3?
Normally I would look for a tool with a good command line interface. But it would be awsome if I could somehow do inline encoding. Maybe via a pipe? Suggestions are very welcome.
Also I have this issue with the system exec.vi I normally use to make command line calls: The VI will only run the command correctly if I make the flag "run until completion" true. This is a real issue, because I really do not want to lock up my code while encoding wav files.
Your suggestions are much appreciated! :)
QUOTE(aart-jan @ Jan 1 2008, 07:57 PM)
Hi all,
original 948 KB
rar 577 KB
OGG 178 KB
If you just want to encode the data after it has been acquired entirely the command line tool approach should work. For longer sound acquisition this may not be desirable and in that case I would simply create an interface to one of the existing open source compression libraries such as Lame, through the Call Library Node. But there is one issue with MP3 that OGG probably wouldn't have, and that is the fact that some companies try to squezze money out of every use of MP3 encoding software. So your application while working technically alright may have legal issues. probably not an issue for a home grown hobby application, but certainly a problem for a professional application.
I'm not sure about the "run until completion" true problem though. I haven't seen this yet and I do make use of the system exec regularly.
Rolf Kalbermatter
