Programatically "Discard Event " in an event structure
QUOTE(TobyD @ Jan 16 2008, 12:08 PM)
Something like this:
http://lavag.org/old_files/monthly_01_2008/post-8758-1200503208.png' target="_blank">post-8758-1200503208.png?width=400
Or as Aitor said you could check that the NewVal parameter is True.
This is what i am doing right now. but I have a "INSERT QUEUE" function that will navigate the control to diferent part of the states in the state machine. On the "value change" from "True" to "False" i would not like to navigate to other states.(rather i would like to stay in the "IDLE" state which is the state where i handle all the value chnages and other events in the EVENT structure). Only when the boolean value is changed from "False" to "TRUE" i would like to navigate. So i need a mechanism to discard the event. It looks like registering this boolean dynamically and handle the events would be a good idea. let me try it out.........
How about simply enabling\disabling the control? That way the user can't trigger a value change event when you don't want to. And if you are programmatically triggering a value change event, you can simply read the status of whether the control is enabled or not, and then decide to execute code.
QUOTE(Yuri33 @ Jan 17 2008, 11:16 AM)
Disabled controls will still trigger an event. That said, you can check if the control is disabled or not, and decide whether to execute the code as you're suggesting.
QUOTE(crelf @ Jan 17 2008, 11:01 AM)
But not by the user, correct? In my experience, if I disable (or disable&gray) a control, when the user attempts to change the control (button press for a boolean, increment\decrement for a numeric, etc.), nothing happens, and no value-change event is triggered. Perhaps the mouse down event is, but not the value change event, and I thought that is what was at issue in this thread.
But I do understand that even if the control is disabled, that doesn't prevent a programmatically triggered value-change event. Hence the second part of my suggestion that you mirrored.
QUOTE(Yuri33 @ Jan 17 2008, 06:31 PM)
But not by the user, correct? In my experience, if I disable (or disable&gray) a control, when the user attempts to change the control (button press for a boolean, increment\decrement for a numeric, etc.), nothing happens, and no value-change event is triggered. Perhaps the mouse down event is, but not the value change event...
Yes - you're absolutely correct. I was thinking of the mouse-up event (the one I use the most on UIs). Sorry for the confusion.
QUOTE(crelf @ Jan 17 2008, 06:53 PM)
I can not disable this "boolean control" since its in the hand of the user/operator. Actually this bollean is having the mechanical action as "switch when pressed" and changing the value from "False" to "TRUE" will start running "Test scripts/suites" automatically one after the another (like loading the config files and stuff like that and all the controls in the front panel except this "boolean" are disabled) . Now Changing the Value from "True" to "False" must "ABORT" the "Test scripts/suites". and hence the "boolean" must always be enabled.
Now the problem is one of the "state" in the "state machine" is responisble for the exectuion of "Test scripts/suites" automatically (its in a while loop(a while loop in a "state" of the "state machine")) and if i changes the value of the boolean from "true" to "False" then the "value" change event gets triggered which i do not want to happen. (since i am taking the control refnum of this boolean and checking the boolean state in one of the subvi) and this event i need to discard.
Hope i have explained enough about the problem.
Also currently i am doing some "QUEUE" operation that will remove unnecessay inserted state during this boolean event and the application is running quiet well without any problem. but somehow i am not happy with this part of the code.. So can anyone please suggest
PS: The event case which handles this boolean event whose property "Lock Front Panel until the event case for this event completes" has been "UNCHECKED"
QUOTE(guruthilak@yahoo.com @ Jan 17 2008, 10:06 PM)
Instead of wiring to the value (signaling) property, which produces a value change event, you can instead wire to the value property, which will change the boolean to whatever you want without triggering a value change event.
