crelf Posted January 18, 2008 Report Posted January 18, 2008 For some reason, the DataAct website keeps crashing my IE7 so I can't get a hold of them. I've been able to limp through and download the installer, but it only installs a few startup shortcuts (I'm using LabVIEW 8.2) - when I run the installer the "dqGOOP" selection is unchecked and disabled, so I'm struggling to install it. Can anyone help? Or, at least, let me know how ot get in contact with someone at DataAct without having to go through their website? Quote
brian175 Posted January 19, 2008 Report Posted January 19, 2008 QUOTE(crelf @ Jan 17 2008, 08:36 PM) For some reason, the DataAct website keeps crashing my IE7 so I can't get a hold of them. I've been able to limp through and download the installer, but it only installs a few startup shortcuts (I'm using LabVIEW 8.2) - when I run the installer the "dqGOOP" selection is unchecked and disabled, so I'm struggling to install it.Can anyone help? Or, at least, let me know how ot get in contact with someone at DataAct without having to go through their website? Did somebody call? Our website hasn't been the same since our web host upgraded to PHP 5 and I haven't had the time to fix it. My quess is that the installer hasn't been updated for the later versions of LabVIEW so you have a couple of options. 1) install into an older version of LabVIEW and copy the directories and files from the project directory or 2) try the zip file which was created for the non-Windows users. The zip file is here I am actually working on dfGOOP which is a framework that uses LabVOOP but allows for "by reference" OR "by wire" and switching between. I am in the process of converting the DataAct Icon Editor from dataFOOP to dfGOOP. If you need to get of hold of me, just send a PM Brian Quote
brian175 Posted January 19, 2008 Report Posted January 19, 2008 QUOTE(brian175 @ Jan 17 2008, 10:31 PM) The zip file is here Sorry, try http://www.dataact.com/downloads/dqGOOP/dqGOOP-1.0.2.612.zip Quote
crelf Posted January 29, 2008 Author Report Posted January 29, 2008 QUOTE(brian175 @ Jan 17 2008, 10:31 PM) I am actually working on dfGOOP which is a framework that uses LabVOOP but allows for "by reference" OR "by wire" and switching between. That sounds just like http://www.endevo.se/index.php/en/Products_General/' target="_blank">Endevo's GDS... Quote
