LabVIEW to Ethernet to profibus
eoin
You could use Modbus TCP for the Ethernet communication. NI has a Modbus library or you could use shared variables with Modbus I/O server. AFAIK, you do not need DSC or RT to use Modbus I/O server in shared variables.
Or, you could get LabVIEW talking on Profibus directly without any gateway.
QUOTE(eoin @ Jan 23 2008, 07:42 AM)
I need help getting labview to communicate some digital and analogue I/O over ethernet to a gateway which then communicates with profibus.
How to go about getting the Values in my labview VI to communivate over ethernet?????
Ethernet is pretty vague as it's a hardware protocol. What software protocol does your gateway use to communicate? It could be EthernetIP or ModbusTCP or something in swahili. Does the gateway have an OPC server?
Tim
QUOTE(Tim_S @ Jan 23 2008, 10:41 PM)
Tim
Sorry for not being specific enough, The gateway is a comsoft FNL which i think uses an OPC server.
QUOTE(eoin @ Jan 24 2008, 01:37 PM)
OPC shouldn't be hard. If you open up the NI Example Finder and search for OPC you'll find several examples, plus there's shared variables.
Tim
