compactRIO module model numbers
ben5248
All NI compactRIO modules come with the model number listed at the top of the front panel in blue.
Some are labeled "NI cRIO-XXXX" while others are labelled "NI XXXX". Is there a difference in functionality?
For example I have seen NI's IEPE module labeld both "NI cRIO-9233" and "NI 9233".
QUOTE(ben5248 @ Jan 24 2008, 07:53 AM)
Probably just a change in marketing. Those modules were introduced with cRIO but in the meantime are also usable with the new USBDAQ modules NI sells. So I guess they decided to drop the cRIO in the labeling to not confuse users.
Rolf Kalbermatter
QUOTE(rolfk @ Jan 28 2008, 04:59 AM)
I'm pretty sure that Rolf is right, as some of the modules can be used as either cRIO or cDAQ modules, so converting the names to a less specific class makes sense.
