Bryan Posted January 25, 2008 Report Posted January 25, 2008 Hello again. I know I've dropped off of the face of the planet for a while. Sorry about that. I'm working on something for a project and have successfully been able to install LabVIEW 7.1 development environment for Linux on a machine running PuppyLinux 3.01. My only problem is that I can't get the RTE to work, although there were no reported errors when I installed it. When I try to run my application from a command prompt, like ./myLinuxLabviewApp . I get the following error: Can't load LabVIEW runtime library /usr/lib/liblvrt.so.7.1 libLVMesaGL.so.3: cannot open shared object file: No such file or directory The files are all there under the /usr/local/lib/LabVIEW-7.1 directory with symbolic links in the /usr/local/lib directory. I don't know enough about linux to find out where it's trying to look for this file. Quote
Bryan Posted January 31, 2008 Author Report Posted January 31, 2008 Well, just as an update, I was able to get the RTE to install and work by using the "ldconfig" command after I installed it to update the shared library links. However, my only problem now is figuring out how to create an image that includes the RTE. Quote
