print data
sara
Hi all
I want in my frontpanel to do button if i press it the table that i read from access will print ..
I use example (access _active x) to read table from access
If you have the professional version of LabVIEW, you should have a palette with VIs for generating reports. One of them accepts a 2D string array. There may be examples for how to use it in the example finder.
