CTITech Posted February 7, 2008 Report Posted February 7, 2008 Im trying to get the max. min and mean voltages from 2 inputs. I can get the data into excel but I only want to see min max and mean, i get a endless stream of voltages. Is there a way I can collect the voltages from that stream and get the desired output to excel? Quote
Louis Manfredi Posted February 7, 2008 Report Posted February 7, 2008 Hi CTITech: Welcome to the LAVA Forum. There's probably someone here who can help you out with your problem... At least I've found that to be the case with many of my own problems. It will be much easier for folks to help you if you can post the vis for the work you've done so far, describe the hardware you are working with, and generally document what you've tried already... That way the gurus will be able to help you out most efficiently. :beer: Good luck & best Regards, Louis Quote
