JustinThomas Posted February 8, 2008 Report Posted February 8, 2008 Any ideas on how to estimate boot up times on a cRIO controller? My current solution is as follows I am currently deploying an executable to the controller with some tcp code to connect to a windows machine. I then monitor the time it takes for the tcp connection to get established after switching on the controller. But I am getting varying results every time I run the test. Also I have noticed that this time is dependent on the following 1. NI software loaded on the controller 2. Model of the controller 3. Size of my executable. I am looking for any suggestions to accurately measure this boot time. Also it would help if I can get any suggestions to minimize the boot time. Regards, Justin Thomas Quote
Neville D Posted February 8, 2008 Report Posted February 8, 2008 QUOTE(JustinThomas @ Feb 7 2008, 03:16 AM) Quote Any ideas on how to estimate boot up times on a cRIO controller? My current solution is as follows I am currently deploying an executable to the controller with some tcp code to connect to a windows machine. I then monitor the time it takes for the tcp connection to get established after switching on the controller. But I am getting varying results every time I run the test. Also I have noticed that this time is dependent on the following 1. NI software loaded on the controller 2. Model of the controller 3. Size of my executable. I am looking for any suggestions to accurately measure this boot time. Also it would help if I can get any suggestions to minimize the boot time. Regards, Justin Thomas Keep pinging it from the Windows machine for 2 minutes. When it responds, its booted up. If it doesn't its either crashed or not switched on. The boot up time does vary with all the variables you have mentioned. Neville. Quote
