How To Access NI-DAQmx in a LabVIEW Project
lvb
In the "Project Explorer" for a .lvproj file, you can create NI-DAQmx tasks/scales/channels. I am looking to modify these dynamically and achieve the following goals:
How to read all channels/tasks/scales in a project?
How to write a channel/task/scale in a project?
How to delete a channel/task/scale in a project?
Below is some code I used to detect what DAQmx items exist, but how can I acess them using the DAQmx property nodes dynamically?
Thanks
post-4274-1203192074.jpg?width=400
post-4274-1203191622.jpg?width=400
QUOTE(crelf @ Feb 16 2008, 06:16 PM)
I was attempting to use the XML file as a last resort. Has anyone made any discoveries if using DAQmx property nodes?
Well first to get all tasks from a project you could get all descendents and filter for DAQmx tasks as type.
Then I think you can call most of the DAQmx functions with a string instead of a DAQmx datatype.
I don't have DAQmx installed on my current computer but it should work.
Ton
