professor_rumsdiegeige Posted February 18, 2008 Report Posted February 18, 2008 Hello forum! I'm using Labview 8.2.1 and the Vision toolbox. I create an image display control on the frontpanel, und I would like to define more than one ROI using this image display control. Is this possible, and if so, how? Thank you in advance. Quote
crelf Posted February 18, 2008 Report Posted February 18, 2008 QUOTE(professor_rumsdiegeige @ Feb 17 2008, 07:00 AM) I create an image display control on the frontpanel, und I would like to define more than one ROI using this image display control. Is this possible, and if so, how? Draw the first ROI, then hold down the ctrl key while drawing subsequent ROIs. Quote
professor_rumsdiegeige Posted February 19, 2008 Author Report Posted February 19, 2008 Thank you. And how can I query those ROIs from the code behind? Currently, I use a refernce to the image display control, use the property "ROI", but with that I only get the first one, right? Quote
AndyDm Posted February 20, 2008 Report Posted February 20, 2008 ZITAT(professor_rumsdiegeige @ Feb 18 2008, 09:23 PM) Currently, I use a refernce to the image display control, use the property "ROI", but with that I only get the first one, right? No, not right. You will get a cluster with two members: bounding rect and array of contours of all ROIs. Try it. best regards, Andrey Quote
