wiggie Posted March 18, 2008 Report Posted March 18, 2008 Hi all, I created a list and I connected to some subvi, and the problem I have is that I cannot select any item on that list while not in edit mode. When I am in edit mode I can select any item without any problems. The way I created the list, is simply by adding it and editing the list items and connecting it to the subVi. I made sure that it is marked as "active" under properties. If I provided to little info on my problem, then please let me know. Here is a screenshot of the list. Cheers, Paul Quote
Jon Sweeney Posted March 19, 2008 Report Posted March 19, 2008 QUOTE (wiggie @ Mar 17 2008, 12:00 PM) Hi all,I created a list and I connected to some subvi, and the problem I have is that I cannot select any item on that list while not in edit mode. When I am in edit mode I can select any item without any problems. The way I created the list, is simply by adding it and editing the list items and connecting it to the subVi. I made sure that it is marked as "active" under properties. If I provided to little info on my problem, then please let me know. Here is a screenshot of the list. Cheers, Paul I may be missing the point of your question, but the following subvi allows the user to select an item from the passed-in "Listbox". If this is not what you are asking, please elaborate. Quote
Doon Posted March 19, 2008 Report Posted March 19, 2008 Hi Paul, I agree with Mr. Sweeny that you are missing a sort of "get user input" method. My suggestion would be to consider an Event Structure that would trigger on a "value change" of the listbox. However, I did notice that you have an array output from your listbox, indicating "multiple selection". This would be a little trickier to implement. If I may, I would like to have more detail on how you handle the list. If you have no need for "multiple selection", I would suggest changing the listbox to "0 or 1 Item" selection mode. have a nice day, --H Quote
