Shortcut Request
I think it would save a lot of time to assign keyboard shortcuts to
1. create constant
2. create control
3. create indicator
You would have to put the wire tool over a connector/terminal so that labview would know what the data type should be. In other words the data type of the item created would match whatever the wiring tool is pointing to.
right click -> context menu -> click on item is okay -- but could be faster.
Anyone concur?
If you wire from an output but don't connect it to anything it remains a broken wire/dotted line. However, if you double click the broken wire it gets tacked down on the block diagram. If you hover over the broken wire and right-click you can create > indicator and the wire will connect to an indicator of the data type.
