Vladimir Drzik Posted April 8, 2008 Report Posted April 8, 2008 Hi guys I have a strange problem concerning notifiers. There are two of of them. In one loop, I fire both of them sequentially. In a second loop, I am waiting for both of them sequentially. Now if the order of the waiting sequence is the same as that of the firing sequence, everything works fine. However, if I'm waiting at first for the second notifier, then for the first one, the latter waiting hangs. I'm attaching a simple VI to demonstrate it. Is this a bug or I am missing something? Vladimir Quote
alukindo Posted April 8, 2008 Report Posted April 8, 2008 Vladimir: If you want these notifiers to behave as two separate ones then you have to initialize them with different 'assigned names'. Else, you really have just one and the same notifier. There is an optional terminal on the create (obtain) notifier VI which you can use to name your notifier reference. Otherwise, the default name is an empty string. This same rule apples to Queue References, Semaphores etc. Actually I think it is good practice to always name your Notifiers, Queue, or Semaphore references even if you are using just one of them. Anthony Quote
Aristos Queue Posted April 8, 2008 Report Posted April 8, 2008 THIS IS NOT A BUG. You can read all about it here: http://forums.lavag.org/Notifier-signals-m...tml&p=17306 Quote
Vladimir Drzik Posted April 8, 2008 Author Report Posted April 8, 2008 Aristos: Thanks, now I understand. I just have some more notes to this issue: Wait for All Notifications is a bit clumsy, since it returns the input notifiers and their notifications in random order - so the notifications have to be ordered after that. I think the "non-safety" of Wait on Notification should be much more stressed in the documentation. One can waste a lot of time tracking the root of such a behavior down (for me it's been a few days ). I vote for adding of the "safe" version of the primitive . Alukindo: Thanks for suggestion. Nevertheless, if you are creating an unnamed notifier, you get a new notifier instance with each call to Obtain Notifier. Vladimir Quote
Aristos Queue Posted April 8, 2008 Report Posted April 8, 2008 QUOTE (Vladimir Drzik @ Apr 7 2008, 01:30 PM) 1. Wait for All Notifications is a bit clumsy, since it returns the input notifiers and their notifications in random order - so the notifications have to be ordered after that. The order should be the same as the order of the original array.QUOTE 2. I think the "non-safety" of Wait on Notification should be much more stressed in the documentation. The docs have been tweaked for future versions. QUOTE 3. I vote for adding of the "safe" version of the primitive . R&D is not at democracy, but as a benevolent dictator, I will take your request under advisement. :-) Quote
crelf Posted April 8, 2008 Report Posted April 8, 2008 QUOTE (Aristos Queue @ Apr 7 2008, 03:36 PM) ...as a benevolent dictator... :worship: Quote
