Using SCC in LabVEIW
Hello, your company uses SVN Server as SCC and TortoiseSVN as front end for it. I bought the PushOK plug in to be able to use SVN directly from LV Project Manager. It seems to work, but I get some problems in understanding it.
My questions are:
1) Which architecture do you use in repositories?
2) I or we use this one:
Local path of a project is e.g C:\MyFiles\LVProjects\TestPrj
So the main module in rep is:
TestPrj\trunk (the current copy of the project)
TestPrj\branches (versions of the project)
TestPrj\tags (releases of the project)
What is the best way to set up SCC in LabVIEW to realize this architecture?
3) If I create a new project I do project-specific settings for SCC:
main-module for Project-Repository is TestPrj\trunk
branches and tags directories will be automaticaly detected
But the local path too ( C:\MyFiles\LVProjects\TestPrj\trunk ), but this is wrong, so I have to change it manually. Any better ways to make it automatically?
4) How can I get any older version of my project from the repository-server? Should I delete my current Project-Directory and check out version I need in the empty directory? I think I get some problems on this step. How do you do this? Can you explain me please?
5) Are there any tutorials how to use SCC in LabVIEW rightly?
Thank you in advice, Eugen
