scls19fr Posted April 8, 2008 Report Posted April 8, 2008 Hello, In my VI which is use with a turbojet I use a finite state machine with the following state STOP / AUTOSTART / MANUAL / PROG I can modify throttle manualy (using a slider) when the state is set to MANUAL. I can send a predefined sequence when the state is set to PROG. The predefined sequence for test is for example a self made square signal generated using a Labview "sequence" for example throttle=40 wait 5000 ms throttle=60 wait 5000 ms and so one... When I click on a "STOP PROG" button I would like that the state instantly turn to MANUAL. So my problem, is that now when I click on "STOP PROG" tge state is only set to MANUAL ***after*** every step of the sequence are finished ! If my PROG (predefined sequence) is very long it's not very conveniant as I have to wait the end of the sequence to abord. Is there an easy way to solve my problem ? Best regards Quote
mross Posted April 8, 2008 Report Posted April 8, 2008 QUOTE (scls19fr @ Apr 7 2008, 04:28 PM) Hello,In my VI which is use with a turbojet I use a finite state machine with the following state STOP / AUTOSTART / MANUAL / PROG I can modify throttle manualy (using a slider) when the state is set to MANUAL. I can send a predefined sequence when the state is set to PROG. The predefined sequence for test is for example a self made square signal generated using a Labview "sequence" for example throttle=40 wait 5000 ms throttle=60 wait 5000 ms and so one... When I click on a "STOP PROG" button I would like that the state instantly turn to MANUAL. So my problem, is that now when I click on "STOP PROG" tge state is only set to MANUAL ***after*** every step of the sequence are finished ! If my PROG (predefined sequence) is very long it's not very conveniant as I have to wait the end of the sequence to abord. Is there an easy way to solve my problem ? Best regards I apologise if I am incorrect, this is starting to sound like school work. We prefer not to answer these things for folks who ought to be working them out alone for school credit. Can you show us a little of your own attempts at coding this so we have an easier chance at making useful suggestions? I am not going to try to model this if you have already done it. And if you haven't already done it, then I shouldn't be doing it for you. IMO. Mike Quote
Justin Goeres Posted April 9, 2008 Report Posted April 9, 2008 QUOTE (scls19fr @ Apr 7 2008, 12:28 PM) The predefined sequence for test is for example a self made square signal generated usinga Labview "sequence" ... When I click on a "STOP PROG" button I would like that the state instantly turn to MANUAL. ... Is there an easy way to solve my problem ? What Mike said is right, but I'll give you a couple nuggets: You can't "break" a sequence. All the frames must execute, from beginning to end. You shouldn't be solving your problem with a sequence. The concept you are looking for is state machine. Quote
scls19fr Posted April 9, 2008 Author Report Posted April 9, 2008 Thanks Ross and Justin for your replies. I think I need to explain the facts. First I'm thirty years old and I pass my exams a long time ago ! Secondly, I teach electronic and physics (thermal science) at Poitiers Institute of Technology (France) So, I'm not a "Labview Advanced Virtual Architect"... therefore I'm looking for help here ! (I won't get credits for this !!!! .... can additional credits be changed for money ?) We own a turbojet WrenTurbines MW54 Mk3. This turbojet has an engine control unit ECU / FADEC (Full Authority Digital Engine Control) Using a serial COM I get data (RPM, EGT, pump power) I also add more sensors (like strain gauges to get thrust, like a pression tranceiver to get air flow using a venturi) and a Labjack U12 data acquisition board. We would like to make a test cell for students. For now we modify throttle using a radio controlled receiver. I design an USB servo tester that simulate the radio controlled receiver when receiving data from Labview (using an ATMEL AVR ATmega8, a FTDI chip, Virtual COM Port driver and NI VISA) http://www.celles.net/wikini/wakka.php?wik...steurDeServoUSB Now I'm looking for a way to send predefined sequences. You can have a look at my VI about this part. see the test_input_step.vi The whole project is in a Subversion directory Web access http://svn.berlios.de/viewcvs/openphysic/l...bo-wrenturbines Anonymous access svn checkout svn://svn.berlios.de/openphysic/labview/turbo-wrenturbines See the trunk directory. "Tags" directory also contains some files Quote
Mellroth Posted April 9, 2008 Report Posted April 9, 2008 QUOTE (scls19fr @ Apr 7 2008, 10:28 PM) So my problem, is that now when I click on "STOP PROG" tge state isonly set to MANUAL ***after*** every step of the sequence are finished ! If my PROG (predefined sequence) is very long it's not very conveniant as I have to wait the end of the sequence to abord. Is there an easy way to solve my problem ? You'll have to create a way to signal that a sequence is aborted, so that the main VI sets a running state and the subVIs just reads the status to see if another step should be taken. This can be done using a number of different primitives/patterns; * using notifiers/queues/occurrences, using these primitives means that you'll have to feed every "sequence runner" with the queue/notifier reference. * using a functional global, i.e. a VI with an uninitialized shiftregister that stores the status information you need. * ... /J Quote
scls19fr Posted April 9, 2008 Author Report Posted April 9, 2008 Wow ! Not sure of being able to do this ! Maybe you have a link that could explain these patterns (using some use cases) Thanks Quote
Justin Goeres Posted April 9, 2008 Report Posted April 9, 2008 QUOTE (scls19fr @ Apr 7 2008, 10:34 PM) Secondly, I teach electronic and physics (thermal science) at Poitiers Institute of Technology (France)So, I'm not a "Labview Advanced Virtual Architect"... therefore I'm looking for help here ! (I won't get credits for this !!!! .... can additional credits be changed for money ?) We would like to make a test cell for students. Aha! So it is for schoolwork! QUOTE (scls19fr @ Apr 8 2008, 02:07 AM) Wow ! Not sure of being able to do this ! Maybe you have a link that could explain these patterns (using some use cases) I haven't downloaded your code to look at it, but there's some information about state machines in the LabVIEW help, and there are some built-in templates that you can find under File >> New... in VI >> From Template >> Frameworks >> Design Patterns. Quote
scls19fr Posted April 9, 2008 Author Report Posted April 9, 2008 I ever made a state machine for STOP/AUTOSTART/MANUAL/PROG About the way of generating a signal (instead of using sequence) I found this http://forums.lavag.org/Generate-my-own-in...ice-t10532.html Express / Input / Simulate arbitrary signal (not sure of the translation because in french it's Express / Entrée / Simuler un signal arbitraire) so I would have to "break" a sequence ! but I also have some questions that could be answered in this post Quote
