while loop with ms wait
Hello,
I'm trying to get loop speed and I've got result that I have not expected.
I set "wait until next ms multiple" to values from 10ms to 0 ms and I want to check how fast the loop runs.
Can anyone explain why when I set 1ms I get 2ms? Is there something wrong with the vi structure?
I attach vi that I use (created in LV8.2).
Download File:post-1959-1207817923.vi
I ran your test and I saw similar results. When the wait time was set to 1 ms, the average wait time was close to 2 ms. BUT, "wait until next millisecond multiple" vi is not made for critical timing. At 1 ms it is probably running up against a wall of how fast it can go back and forth between the OS. The wait until vi is like a sleep command that allows the OS to perform other tasks. If you are looking for better timing use the timed loop. I replaced the while loop with a timed loop in your example and I observed a measured time of 1.025ms for a setting of 1.0ms.
Download File:post-151-1207831749.vi
Too much time with Windows, and I totally forgot that TimedLoops were made for RT targets. With TimedLoop on cRIO I also get nice 1.01 ms, but even cRIO can't squeeze 1ms from a standard "while" (with RT version of "wait until..." ).
Thanks for the reminder! :)
QUOTE (souske @ Apr 10 2008, 09:18 AM)
I don't know anything about your application, but have you considered doing your ultra-time-critical work in FPGA? Or maybe some of it and then stream data as needed to the RT host?
QUOTE (souske @ Apr 10 2008, 03:18 PM)
If you enable us support on the cRIO you can probably get closer to the 1ms target, by using the RT specific "Wait until next multiple" with 1000us as input.
/J
  • 2 years later...
