how can i acquire image from tv card [AVerTVStudio203(M168)]
Is it possible to acquire images from our tv card instead of cameras?
i am trying to test the outputs of a dvbs (satellite receiver),
by these steps
1] we will feed the tv card inputs (composite,s-video,TV ) by our receiver under test's output...
2] the receiver plays a constant stream for example (color bar)
2] we will acquire images from tv card
3] and compare these images with the correct files at the pc (jpeg files)
i just wonder is it possible to realize such a project ?
also we should select the tv cards inputs from labview , i mean switch between (composite,s-video,TV ) inputs.
best regards
no external hardware just tv card and labview 8.5
You will need IMAQ and Vision software, but you will also need a way to communicate with the hardware. If the hardware has ActiveX components it should be doable. Some companies have well-developed ActiveX/Com libraries and SDK's. Others have squat. You will have to contact the manufacturer.
  • 2 weeks later...
