Ed Dickens Posted April 28, 2008 Report Share Posted April 28, 2008 The "Convert Panel To Screen Coordinates" method does not work on VIs in Run mode. If you use this method on a VI in Run mode, you receive the follow error. "Error 1073 occurred at Invoke Node in CvtPanelToScreenCoords.viPossible reason(s):LabVIEW: This property is writable only when the VI is in edit mode, or this method is available only when the VI is in edit mode.Method Name: Convert Panel To Screen Coordinates" The help file indicates this is the correct behavior stating that it is not settable when the VI in running. I brought this to NIs attention and they agree that the method is not very useful on a VI in Edit mode, so they filed it as a bug (CAR # 105629). Download File:post-47-1209311080.vi Quote Link to comment
hfettig Posted December 16, 2010 Report Share Posted December 16, 2010 Did you ever find a way around this problem? I can convert the horizontal coordinate without any problems but the vertical seems to depend on whether the toolbar is on, etc as well as on the windows theme. I am trying to convert the screen coordinates that I get from Acquire Input Data.vi, i.e. reading the mouse position, into Panel and then Pane and then XY Graph coordinates. Heiko Quote Link to comment
Ton Plomp Posted December 16, 2010 Report Share Posted December 16, 2010 This is fixed in LabVIEW 8.6 Ton Quote Link to comment
hfettig Posted December 16, 2010 Report Share Posted December 16, 2010 Actually it is still a problem in LV 2009 SP1. It works fine in the IDE but does not work in the RTE. I did find a workaround. To get the Pane coordinates you can subtract the Screen coordinates from the top left corner of the Panel Bounds and add the pane Origin. Heiko Quote Link to comment
