"Convert Panel To Screen Coordinates" method
The "Convert Panel To Screen Coordinates" method does not work on VIs in Run mode.
If you use this method on a VI in Run mode, you receive the follow error.
"Error 1073 occurred at Invoke Node in CvtPanelToScreenCoords.viPossible reason(s):LabVIEW: This property is writable only when the VI is in edit mode, or this method is available only when the VI is in edit mode.Method Name: Convert Panel To Screen Coordinates"
The help file indicates this is the correct behavior stating that it is not settable when the VI in running. I brought this to NIs attention and they agree that the method is not very useful on a VI in Edit mode, so they filed it as a bug (CAR # 105629).
Download File:post-47-1209311080.vi
  • 2 years later...
Did you ever find a way around this problem?
I can convert the horizontal coordinate without any problems but the vertical seems to depend on whether the toolbar is on, etc as well as on the windows theme.
I am trying to convert the screen coordinates that I get from Acquire Input Data.vi, i.e. reading the mouse position, into Panel and then Pane and then XY Graph coordinates.
Heiko
Actually it is still a problem in LV 2009 SP1. It works fine in the IDE but does not work in the RTE.
I did find a workaround.
To get the Pane coordinates you can subtract the Screen coordinates from the top left corner of the Panel Bounds and add the pane Origin.
Heiko
