Problems with DAQ card
reem
Hi everyone...
a sinewave is generated -as shown in attached picture -that it's amplitude andfrequency is controlled using knobs. i did the same using DAQcard
and Tone measurementbut it mentioned that the numerics(knobs) i use must be as indicators and not control...
so,
how is it possible to control the amplitude, frequency of signal from DAQcard?? shouls i use any other function in between??
i'll be thankful for any suggestion and help :)
Reem..
LV_Printf - 2011.zip
QUOTE (reem @ Apr 28 2008, 07:58 AM)
reem,
alzhrani's question was what type of physical card, in other words the DAQ itself. You've shown us a picture of the programming interface you are using, in this case an express VI.
There's no reason why you can't use Controls. I think you're missing something on a higher level.
QUOTE (reem @ Apr 27 2008, 03:44 PM)
how is it possible to control the amplitude, frequency of signal from DAQcard?? should i use any other function in between??
Without knowing what hardware you're using, I would suggest creating a task and then writing chunks of the output as needed. You would change the amplitude and frequency as you write out chunks, though I would recommend completing at least a half-cycle (waveform is a 0) to avoid discontinuities.
Tim
QUOTE (BrokenArrow @ Apr 28 2008, 05:49 PM)
i'm using this one: (if this is what u mean :) )
post-11300-1209406483.jpg?width=400
probably there is something (maybe a function)to use so i can control the signal from hardware but i'm using labview for like
3 month only and i don't know what exactly to look for?!!
QUOTE (Tim_S @ Apr 28 2008, 06:35 PM)
Tim
creating a task and then writing chunks of the output as needed?? :unsure: how??
can you show me an example if possible???
Thank you all for ur help...
Reem
QUOTE (BrokenArrow @ Apr 28 2008, 11:31 PM)
Reem,
That's not a DAQ, it's a breakout board. I honestly think you're missing some high level knowledge. Is there anyone where you work that has programmed in LV that can help you? "Creating a Task" is plain LabVIEW talk. Read up on MAX (Measurement & Automation Explorer), DAQmx, and find your DAQ!
yes,,,i know i have alot to learn ahead of me but since i don't have enough time i asked the
question just to get a quick answer but seems that there isn't such thing !! :)
where i study ,they have all used old version of labview and seems they don't have enough information to help me...
Thanks for the advice ...
