Waweform graph values to spreadsheet
Hello I would like write values that are shown in waweform graph-dynamic data to spreadsheet file. I Attach Vi that I did, I wrote that to measurement file and I need something like that but to TXT file,how could I do that? Thank you
The Express>>Signal Manipulation palette has a From DDT VI which will allow you to convert the DDT data to a 2D DBL array, which you can then write to a spreadsheet file using the Write to Spreadsheet File VI from the file palette.
