Fran Posted June 4, 2008 Report Posted June 4, 2008 Hi all! Actually i don't know wether this is the right forum for this post or i should try in the programming one but i'm not sure that it is a hardware problem or a software one. I have a scc-ctr01 counter module in a sc-2345 carrier and a DAQCard-6024E. I use this SCC module as a counter for frequency measurement in an application developed using Labview 7 Express over a Toshiba Satellite Pro 4300 laptop. In the same application at the same time i get analogic input data from a scc-sg24 strain gauge module. No problem at all. I tried to migrate this configuration and application to a Dell Latitude D630. In the MAX i made a new configuration copying the old one. In the Dell i have installed Labview 7.1. Both computer have Win XP SP2. When i run the application in the Dell (with the new channels configured in the DAQassistants) i don't get any error but i runs very very slow. The graphs are drawn step by step and when i try to stop it the system needs seconds from the mouse click to the application stop. If i erase the DAQassistant of the frequency counter from my VI the applications runs right (without the frequency data, of course). I have test other applications using the data of the SCC-SG24 modules and they work well. I tried to swith off one of the CPU cores (i read there are some problems with LV 7.1 and dual core CPUs) but it didn't work. Any ideas?. Hardware problem?. Software problem?. Thanks in advance!. Cheers! Quote
Neville D Posted June 4, 2008 Report Posted June 4, 2008 Without seeing your code, I have no idea, but what sample rate are you using? Neville. Quote
Fran Posted June 5, 2008 Author Report Posted June 5, 2008 Hi Neville. In the working application in the old Toshiba, the DAQAssistant for frequency measurement in configurated for a max input frequency of 150 Hz. Task timing is in continous adquisition mode with 20 samples. Anyway, i don't think i t could be a programming error because it's working in the old laptop and the applications are the same in both PCs. The question is there isn't any error code in the execution. It only runs slowly in the new PC, without crash. Thank you for your response! Quote
