Read the Analog Input
hakannn
Constant physical channels you currently set as single chanel.
Open physical channels and select Browse... then click with Ctrl button pressed to select more than one physical channel.
You could also set adress that way:
QUOTE
Dev1/ai1:5
then you will use channel 1, 2, 3 , 4 and 5
hi jgcode,
thanks for your reply.
i tryied your solution but i couldn't managed it. ( The next step is to build a circular buffer" i couldn't understand, what does it means "circular buffer"?? :s )
after i tryied other solution and i saw signals.
the last problem about program,
The program can't save the "coefficent" and "plus" number. can i save this number. i don't want to write it everytime when i open the program
i hope i'll solve that problem.
again, thanks for everything...
hakan...
QUOTE (hakannn @ Jun 6 2008, 07:37 PM)
hi jgcode,
Making a 2D array is a solution for a waveform GRAPH
Another solution is to use the waveform CHART like you have done and let the chart handle buffering (which is statically set).
You may find handling your own buffer is more flexible, but if you are after a quick solution the chart is actually probably the easiest.
If you need to save your scale and offset and the values do not change per collection then convert them to a string and write them to disk as a header in your collection file is an option.Do this before you enter the loop. If the values do not change there is no point continually polling the FP panel every time you do a read.
