Reading both digital and analog signals in the same VI
georgekm
Is there a way to read both digital and analog signals in the same VI? I have an encoder line that is used as a trigger for aquiring data from an analog input. But I also want to be able to plot the encoder signal. Is there some way to do this?
Thx
QUOTE (georgekm @ Jun 6 2008, 11:05 AM)
  Quote
Thx
I'm not sure what you mean by "...in the same VI". Do you mean, in one VI? For example (and to jgcode's point), using DAQmx, you can make one Multi-Function VI that does ALL of your Digital & Analog reads and writes. Of course, this one VI will contain several polymorphic sub VI's, but these ship with LabVIEW, your one VI (i.e. same VI) just makes calls to the other VI's. Do you need an example? We also need to know what interface (driver) you are using: DAQmx, NI-DAQ (i.e. Traditional DAQ), or third party.
Richard
Thx guys,
I figured out the mistake I was making. I had two DAQmx read VIs trying to access the same channel at the same time. I've now wired the error out from one read vi to the next one so that the two activities are performed one after the other.
ge
