Switching between DAQmx and DAQmx base on Vista
In order to be able to switch between NI-DAQmx and NI-DAQmx Base, you must have both the NI-DAQmx and NI-DAQmx Base drivers installed on the PC. More specifically, you must have these versions of the DAQ drivers:
NI-DAQmx Base 1.4 or later
NI-DAQmx 7.5 or later
If you do not have these drivers you will need to install both of them to switch your firmware. See current drivers linked below to download the latest version(s).
Above is from last paragraph of this link to resolve issue:
http://digital.ni.com/public.nsf/websearch...10?OpenDocument
