Tyler Shogren Posted June 7, 2008 Report Share Posted June 7, 2008 How can you switch between using DAQmx and DAQmx Base on Windows Vista. I am using an USB-6009. This KB article fails at step 6... only one driver is listed. Any suggestions appreciated. Quote Link to comment
AnalogKid2DigitalMan Posted June 7, 2008 Report Share Posted June 7, 2008 In order to be able to switch between NI-DAQmx and NI-DAQmx Base, you must have both the NI-DAQmx and NI-DAQmx Base drivers installed on the PC. More specifically, you must have these versions of the DAQ drivers: NI-DAQmx Base 1.4 or later NI-DAQmx 7.5 or later If you do not have these drivers you will need to install both of them to switch your firmware. See current drivers linked below to download the latest version(s). Above is from last paragraph of this link to resolve issue: http://digital.ni.com/public.nsf/websearch...10?OpenDocument Quote Link to comment
Tyler Shogren Posted June 13, 2008 Author Report Share Posted June 13, 2008 Situation resolved. Quote Link to comment
