Disconnect a Polymorphic VI from a lvlib?
crelf
Normal VI's have a File > Disconnect from Library menu item, but polymorphic VIs don't. If a poly is part of a lvlib, and the lvlib is deleted, the poly is broken with a "This VI is connected with a library that LabVIEW cannot find. Find and load the library or select File»Disconnect from Library" message. I don't have the original lvlib, and there's no File > Disconnect from Library menu item - how do I fix my poly?
Solution: save it under a new name - the new copy will be disconnected from the lvlib. I'd call that a bug.
QUOTE (crelf @ Jun 16 2008, 06:22 PM)
Oddly enough, i hade that happen with the write to spreadsheet file. i lost all my polymorphic instances except one.
NI had me recopy the original lvlib from the CD to my computer and replaced the broken one with that. All was good.
  • 2 weeks later...
