Gabi1 Posted June 21, 2008 Report Posted June 21, 2008 How many times did I forgot to set a boolean constant in a case to 'true', leading to an infinite loop condition?? in some project the run time is long, and therefore debug time is exponential: why not allow code change while program is in 'pause mode': i discover a bug - dont want to restart the whole process - pause, change the wire, structure or element - and then continue running. It is possible in VB for example. works perfectly there. Why not in Labview? Quote
LAVA 1.0 Content Posted June 21, 2008 Report Posted June 21, 2008 QUOTE (Gabi1 @ Jun 20 2008, 09:05 AM) How many times did I forgot to set a boolean constant in a case to 'true', leading to an infinite loop condition??in some project the run time is long, and therefore debug time is exponential: why not allow code change while program is in 'pause mode': i discover a bug - dont want to restart the whole process - pause, change the wire, structure or element - and then continue running. It is possible in VB for example. works perfectly there. Why not in Labview? I think this is already planned. I heard of it but I don't remember where... Didn't NI (tried to) show this at the last NI Week? So in future (what ever future means) you can "just" edit a running programm... :thumbup: Quote
