LAVA 1.0 Content Posted June 25, 2008 Report Posted June 25, 2008 I have struggled a bit before noticing that if I have a graph overlaid ever so slightly over an intensity graph, adjusting the scale of the intensity graph using the scale legend buttons does not fire a "scale range changed" event (even though the intensity graph is actually updated). Interestingly, changing the scales manually (by modifying one of the displayed number on the scale) still fires an event. It may be more general than that, but this is annoying enough for my purpose. If anybody wants to check this out, I have attached two simple Vis that illustrate this phenomenon. I have reported the potential bug to NI. Best, X Quote
