Xrockyman Posted June 26, 2008 Report Posted June 26, 2008 Hello, I'm using labview 8.2.1, in the front panel of a VI (when he is nor running) if we right click on a control we an option called "Disable and grayed". My doubt is if it is possible to change this option when the progam is running. I have "log-in" system in my program and depending the permissions of the user I want to "disable and gray" or activate the control. Thanks in advance and sorry about my bad english! Regards, Sylvain. Quote
TobyD Posted June 27, 2008 Report Posted June 27, 2008 QUOTE (Xrockyman @ Jun 25 2008, 03:36 PM) Hello,I'm using labview 8.2.1, in the front panel of a VI (when he is nor running) if we right click on a control we an option called "Disable and grayed". My doubt is if it is possible to change this option when the progam is running. I have "log-in" system in my program and depending the permissions of the user I want to "disable and gray" or activate the control. Thanks in advance and sorry about my bad english! Regards, Sylvain. Read up on Property Nodes. Specifically the Disabled property. Quote
Xrockyman Posted June 27, 2008 Author Report Posted June 27, 2008 QUOTE (TobyD @ Jun 25 2008, 11:48 PM) Read up on Property Nodes. Specifically the Disabled property. Thanks it was just what I needed !! Regards, Sylvain Quote
Xrockyman Posted July 10, 2008 Author Report Posted July 10, 2008 Hello, I've made a easier solution, maybe is not so pretty but is easier to understand It consist using rings and property nodes(in this case "visible" and "disable"). My vi goes on the attachment. Regards. Quote
