Problem opening older version
I have projects written in LabVIEW 7.1 and can open them with no problems in LabVIEW 8.5 the only problems you might encounter is driver incompatibilities and if any of your code has the block diagram removed, there might be other upgrade issues too, the release notes would contain more information. The only VIs I've found that have been too old for LabVIEW 8.5 to open at all are LabVIEW version 5.1 or older.
QUOTE (normandinf @ Jun 27 2008, 03:47 AM)
QUOTE (Karissap @ Jun 27 2008, 04:16 AM)
I cannot seem to view my Sub VIs for the port read and config. There is this question mark image on the block for the Sub VIs
