Altomare Posted July 15, 2008 Report Posted July 15, 2008 Hi, I have 2 images: the 1st one is my reference (template) the 2nd is an image of the same object but it is traslated (dx, dy) and rotated (alpha). I need to calculate dx,dy and alpha in order to reposition the image over my template. I was thinking to use rototraslation matrix to calculate the parameters. Do you know some algorythm for this kind of application? Thanks a lot. Quote
LAVA 1.0 Content Posted July 15, 2008 Report Posted July 15, 2008 QUOTE (Altomare @ Jul 14 2008, 03:26 PM) Quote Hi, I have 2 images: the 1st one is my reference (template) the 2nd is an image of the same object but it is traslated (dx, dy) and rotated (alpha). I need to calculate dx,dy and alpha in order to reposition the image over my template. I was thinking to use rototraslation matrix to calculate the parameters. Do you know some algorythm for this kind of application? Thanks a lot. Hello, There is such functions in the IMAQ toolkit, it's called "IMAQ match pattern 2" and lets you specify if you expect your object to only translate, only rotate or do both. There are exemples that ships with the toolkit to demonstrate how to use this function. http://lavag.org/old_files/monthly_07_2008/post-7452-1216043150.png' target="_blank"> Hope this helps Quote
