jcz Posted July 17, 2008 Report Posted July 17, 2008 Hi, One of the cursors (the green one) on my XYGraph somehow shifted itself and is no longer above the cursor (see screenshot). I have no clue how to fix it (apart from deleting the cursor, adding new and setting everything from scratch). Any suggestions ? Jakub Quote
Jeffrey Habets Posted July 17, 2008 Report Posted July 17, 2008 If you have "Allow drag" for the cursor set to off you can't drag the label either. So that wouldn't be an option. You can set the label offset to the cursor position in the "Cursor list" property. Mind you that if you have a scale multiplier set other than 1 to one of the scales the cursor is connected to. The cursor label will "drift away further" from the cursor position each time you change the position. This is a bug in LV. Quote
