System Exec with MSC File
Hi to all,
I'm trying to launch the Disk Defragmenter (C:\WINDOWS\system32\dfrg.msc) from LabView, but via several attempts I have only gotten the Windows error 193 (invalid Win32 application) or a floating command (DOS) window. Here is a summary of the inputs and results for System Exec for the tests I've tried:
Command Directory StdIn Result
dfrg.msc . (blank) Error 193
"C:\WINDOWS\system32\dfrg.msc" . (blank) Error 193
cmd . dfrg.msc Command window in current VI directory
cmd C:\WINDOWS\system32 dfrg.msc Command window in system32 directory
If I run either of the first two Command values using the Windows "Run..." the Defragmenter is launched.
Does anyone have any suggestions? I'd really appreciate the help!
By the way, for those who replied to my post in March about preparing for the CLD (incidentally, it disappeared from the LAVA forum), I passed with flying colors and am proud to now call myself a Certified LabView Developer! Thanks again for the studying tips.
Nevermind, I figured out a solution while playing around. For those who are curious, I created the following batch (.bat) file:
exit
Calling the batch file with System Exec successfully launches the Defragmenter.
I guess I was too eager to ask for help!
The following should work without the need for a batch file......
post-9410-1216662499.jpg?width=400
QUOTE (OrangeAndGreen @ Jul 21 2008, 05:22 PM)
exit
