rav Posted July 23, 2008 Report Posted July 23, 2008 We are working with GOOP 3.0.0 After starting the project we enabled SCC. All files in my Project / Class are checked out,a If I create a new Method (GOOP --> Add method), following message appea after pressing "Create Method": "File permission error. You do not have the correct permissions for change a file. The file might be read-only (checked in). Make sure all files in your class are editable." How can I find out, which file is affected? The Method-VI is created, but wrong/no Icon, no description, no linkage to class Quote
LAVA 1.0 Content Posted July 23, 2008 Report Posted July 23, 2008 QUOTE (rav @ Jul 22 2008, 09:55 AM) We are working with GOOP 3.0.0 After starting the project we enabled SCC. All files in my Project / Class are checked out,a If I create a new Method (GOOP --> Add method), following message appea after pressing "Create Method": "File permission error. You do not have the correct permissions for change a file. The file might be read-only (checked in). Make sure all files in your class are editable." How can I find out, which file is affected? The Method-VI is created, but wrong/no Icon, no description, no linkage to class Are you sure everything of the class is checked out? We don't have issues with the setup you describe. Ton Quote
rav Posted July 23, 2008 Author Report Posted July 23, 2008 After serarching long time I found the solution: I was using a Methode-Name (Vi-Name) which was not accepted by GOOP (but the name is accepted in LabVIEW as normal vi name) --> Problem solved. Quote
