picard1933 Posted July 25, 2008 Report Posted July 25, 2008 How do you make a menu bar below the standard menu items? I would like to make custom buttons under the normal menu bar, similar to LV programming environment: Brent Quote
Yair Posted July 25, 2008 Report Posted July 25, 2008 You can split the panel into multiple panes. Then, the top pane will serve as your toolbar. There are probably examples in the example finder. Quote
picard1933 Posted July 25, 2008 Author Report Posted July 25, 2008 QUOTE (Yair @ Jul 24 2008, 12:30 PM) Quote You can split the panel into multiple panes. Then, the top pane will serve as your toolbar. There are probably examples in the example finder. Thanks. I should have thought of that. Brent Quote
