viSci Posted July 30, 2008 Report Posted July 30, 2008 Greetings, Does anyone know if it is possible to run the PTP protocol on a cRIO? I currently plan on using the cRIO trigger input to receive a GPS 1s sync output. The newer cRIO's have a .ini switch to enable RTC correction. Thanks, Quote
LAVA 1.0 Content Posted July 30, 2008 Report Posted July 30, 2008 QUOTE (sachsm @ Jul 29 2008, 07:28 PM) Greetings,Does anyone know if it is possible to run the PTP protocol on a cRIO? I currently plan on using the cRIO trigger input to receive a GPS 1s sync output. The newer cRIO's have a .ini switch to enable RTC correction. Thanks, Hi SachSM, you should get in touch with Wiebe from http://www.carya.nl' rel='nofollow' target="_blank">Carya.nl They have done nice things on SAR beacon testing for Galileo. A (dutch) presentation is available under 'Downloads'\Presentations\NIDays NL & BE 2007. Ton Quote
